2001 dodge ram 3500 DRW mods
Old Apr 20, 2013 | 09:40 PM
malvothegreat's Avatar
Question 2001 dodge ram 3500 DRW mods
Hello you guys I bought this truck to pull a 53 foot wedge with cargo trailers on it and I wanted opinions on what performance mods I should do to the truck as far as programmers exhaust etc. The truck is bone stock now. Thanks you guys
Old Apr 23, 2013 | 11:14 AM
MillerBoyzDiesel's Avatar
If it doesn't have some kind of aftermarket lift pump, id start there first. Then cold air intake and turbo back exhaust. If towing a lot aftermarket gauges are deff. something worth having. Depending on power youre looking for will determine the tuner/box you want. Id say for a tow vehicle an edge ez would be one to look at. What type of transmission is in the truck?
Old Apr 24, 2013 | 01:47 PM
chuffysplace's Avatar
chg trans filter and adjust bands if it's an auto.
#1-Gauges, fuel pressure at a minimum. If lift pressure is low, get ready for a $1000+ bill for an injection pump, as that means the pressure has been low and it's been hurting the VP44 injection pump (not good). Hopefully you'll have good pressure. A healthy 14-18 is good at idle or cruising
#2-Aftermarket lift pump, FASS or AirDog. How big of a pump depends on how much power you want down the road. Some people run 150 models with fuel and water separators.
#3-Cold air intake and free flow exhaust
#4-Tuner. For mileage and a little more giddy-up, I'd go with a Smarty, if you'd like more power and built in gauges, so you can monitor many vitals (EGT, fuel pressure, boost, trans temp, etc) that is back up camera compatible - go with an Edge CTS
#5-Injectors and/or Turbo
Hope this helps. -Chris
Old May 6, 2013 | 08:04 PM
It's an auto
Jet A Fuel
For Sale
Aug 16, 2015 04:44 AM
raude1
Apr 13, 2015 03:38 PM
nelly559
Feb 2, 2015 08:19 AM
Nov 3, 2014 08:10 AM
jstoshick
For Sale
Oct 2, 2014 10:24 PM
