48re Limp Mode!!
Old Apr 14, 2013 | 05:49 AM
muddinfreak89's Avatar
Default 48re Limp Mode!!
Replaced gov pressure sensor and solenoid, no change. Getting p0700 code which from my understanding is a common trans fault code, thinking about changing the wiring harness for the gov pressure sensor and solenoid amd seeing what that does. Currently the truck starts out in third gear and has no lockup, can manually pull into second and can only get first manually from a shift from reverse. Any help would be greatly appreciated thanks CPL COLLIER USMC
Old Apr 28, 2013 | 06:14 PM
Still having this issue, replaced the gov sensor and transducer and the overdrive solenoid, no change come on guys, been almost 70 views and no responses
Old Apr 28, 2013 | 09:04 PM
Dustin M's Avatar
sorry to hear about your problem.i had similar problems out of mine a few months back.they replaced the throttle control valve(the computer thing on the driver side of the transmission) and that one went out and the ended up replacing the valve body and still going strong now. Might have the throttle control valve checked out first.sorry I couldn't be more help.hope you get it figured out
Daniel Leipart
Jun 28, 2015 02:42 PM
ClintD.
Chevy/GMC Duramax 06-07 LBZ
Mar 23, 2015 04:37 AM
syctaz
Mar 3, 2015 09:23 AM
To fast
Chevy/GMC Duramax 04.5-05 LLY
Feb 10, 2015 09:30 AM
Brandanllewellyn
Oct 20, 2014 08:09 PM
