12v cummins wont start after running out of fuel
Old Apr 10, 2013 | 04:14 AM
makeitsmoke's Avatar
Default 12v cummins wont start after running out of fuel
Hi guys new here and to cummins i have 91 bluebird 6bt that i ran out of fuel i belive never had any running problems before so this is what ive done put fuel in it turned it over a few times then took of fuel filter to prime it was full i put it back on fired up ran good let it run few hours turned it off next time i tried to start no luck so iput more fuel init check filter its full pushed primer bulb a lot took inj lines lose most of them any way not one drop of fuel came out the lift pump seems to pump good threw the filter i did notice i didnt hear the fuel shutoff working a few tries but it is now what do you guys think ? Can there be a problem in the shutoff or does it sound like injector pump also last night i ran my ram out of fuel also had a hard time getting it going thanks for any info
Old Apr 12, 2013 | 08:47 PM
Beachin Diesel's Avatar
Did you make sure the line from lift to injection pump wasn't air locked?
Old Apr 12, 2013 | 09:02 PM
Im getting fuel past the lift pump and threw the outlet on fuel filter .so i should break the line lose on the injection pump? Is there any bleader on the pump? Also my # is 2055687876 if any one want to text any info
Old Apr 13, 2013 | 07:26 AM
No bleeder just have to loosen fitting on IP then cycle key, but do not crank, till fuel is present. Once you have fuel at IP you will have to go through and bleed all injector lines. Much easier to do if you have someone in cab.
Old Apr 23, 2013 | 12:46 PM
Default still no luck
Still not a drop has come out of injection pump the lift pump seems to be doing itß job i dont have a gauge but pumps well so does the primer ran fine when i shut it off ive read about something sticking in the inj. Pump can any one share some wisdom i dont know how it works but seems like the fuel shuttoff has stuck close the arm is moving please help
Old Apr 24, 2013 | 07:21 AM
coalroller12valve's Avatar
Once u check your fuel shut off crack all your injector lines loose (on top of the motor) turn it over a few times then if that dont work try the vacume pump method try to get fuel to come up to ur injectors if fuel dont get up there you more than likely need a new pump
I had a simular problem to this got it to run it ran for a hour started up fine so i let it sit overnight next day i go out start it up to leave i go about 50 yards and it dies and wouldent start so i pulled er in the garage pulled the pump sent it to cadiz diesel and turns out it needed rebuilt when theres wear on these pumps one time running out of fuel will set u in the hole
Last edited by coalroller12valve; Apr 24, 2013 at 07:21 AM. Reason: Automerged Doublepost
Old Apr 24, 2013 | 11:05 AM
What is the vacume pump method i have fuel to injector pump but nothing coming out not a drop
Old May 1, 2013 | 07:34 PM
Seth'sCummins's Avatar
You do need to crank the engine so the pump will pull fuel. The pump is mechanical and not electrical so the engine needs to be turning.
You are not getting fuel past your injection pump? Could your injection pump be air locked?
Cavnar
Sep 9, 2015 07:18 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
Collin Dow
Feb 21, 2015 08:18 PM
moneypitk5
Feb 12, 2015 11:01 AM
