94-98 7.3L Performance Discussion of 94-98 7.3 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
how many miles are to many
Old Apr 9, 2013 | 10:04 PM
Oklahoma diesel's Avatar
Default how many miles are to many
OK, I just bought a 97 f350 it has 283xxx miles. I plan on pulling the engine for my 94 f250. My 94 has a h2e turbo from hypermax intercooler, computer, and I think injectors. Don't know the HP ratings with all the stuff, but. Will my 283xxx mile engine be ok with this stuff?
Old Apr 10, 2013 | 05:19 AM
POWER-STRUCK's Avatar
if a compression test is good then I could not see a reason why not
Old Apr 10, 2013 | 06:28 AM
autostroker's Avatar
just keepe an eye on your EGT's, as long as you dont get too hot, you should be okay.
Old Apr 10, 2013 | 09:39 AM
Haven't run a compression check yet, but it has almost no blow by. I know the engine that's in my 94 now is bad due to it being a hot shot truck with someone who dissent know how to read the guages, the pyrometer is in the manifold right after the # 8 cylinder and it gets to 900 really quick, I think its because of the hole in the piston but not sure till I tear it down. How many miles can you get out of a 7.3 with good maintenance?
Old Apr 10, 2013 | 11:37 AM
i have one with over 700,000 miles and have a customer with 1,300,000
Old Apr 10, 2013 | 11:44 AM
Next question is, where can I take my turbo to be rebuilt, and test my injectors? Both of those trucks are factory builds?
Old Apr 14, 2013 | 10:17 PM
How much boost will the factory head bolt and gaskets hold?
Old Apr 27, 2013 | 06:00 PM
rocksmearer's Avatar
mine will boost to 42 if I have her cranked all the way up. It has held for about 4 years. I generally dont drive like that and its possible I've just been lucky. My sister used to date a cinematographer, every one knew he was really a pornographer.
Old Oct 17, 2013 | 05:34 PM
B.Reilly01's Avatar
I bought a 1997 E350 Shuttle Bus (handicap body) with 369K on it. I pulled the motor (swapping into a Dodge), and I'm doing the bearings right now because... well, it has 369K on it and it's out. Bearings were very worn when I pulled them, but not knocking. The rings on mine are so strong I have to struggle to pull against closed valves to re-seat the rod bearings. These PSDs are strong and durable. I'd do bearings while it was out. I was skeptical about doing it, but rolsmohave3 convinced me to.
Have they been rebuilt at all? What about bearings? Rings/Pistons?
Last edited by B.Reilly01; Oct 17, 2013 at 05:34 PM. Reason: Automerged Doublepost
Hoss3615
Jan 22, 2015 08:14 AM
Brendan Kahle
For Sale
Jan 14, 2015 12:35 PM
Jan 5, 2015 01:40 AM
Nov 21, 2014 01:30 PM
