Audio Equipment/Electrical Discussions Based on Automotive Stereo Equipment Such As Amps , Head Units & Speakers Including Installation and System Set Up Information. Electrical or wiring issues on anything that requires wiring.
6.0 GPCM Bad?
Old Apr 7, 2013 | 09:23 PM
Stuart W's Avatar
Default 6.0 GPCM Bad?
When my 2003 6.0 is off, I have 0.5 amps running thru the GPCM / Alternator cable. With the alternator completely disconnected, there is still a 0.5A draw which points to the GPCM or its harness. Anyone run into this issue or have any ideas?
More pieces to the puzzle. The truck starts and runs fine otherwise. Before I got a DC clamp meter, I hooked up an amp meter after disconnecting both batteries and reconnecting only one, I was seeing around 0.230 A draw but after about 10 minutes, the draw drops to around 0.060 A. I never saw a 0.5A draw. So I'm guessing that if I were to disconnect the batteries again and reconnect them, the 0.5A draw will go away which points to electronics (i.e. GPCM and not the harness).
Thanks
BeastFromTheEast
Aug 4, 2015 10:06 AM
Powerstrokin7.3
Jun 13, 2015 08:47 PM
scubasteve12
Mar 29, 2015 09:39 PM
thumperf350
Jan 8, 2015 12:55 AM
GWest
Oct 12, 2014 09:22 PM
