southbend, stock hydrolics
Old Apr 6, 2013 | 03:56 PM
codycatract's Avatar
Default southbend, stock hydrolics
i have a south bend the guy said it was a stage 3 single disk, downfall hops pretty bad at take off not for a daily driver but it has stock clutch hydrolics. when im at a dead stop in take pretty long to put into gear to take off from a stop light, but shift just fine. the clutch predal does not need adjustment because it engages with pedal half way out, if i get the valair or southbend hd clutch hydrolics would this be fixed?
Old Apr 6, 2013 | 04:20 PM
94 12valve's Avatar
will not fix the hop issue or the putting it in gear issue ... easy fix for the gear issue is put it in 3rd than in 2nd. 3rd gear has a syncro 2nd does not
Old Apr 9, 2013 | 04:45 PM
NEWBIE 98's Avatar
I sit possible that the clutch slipped alignment when it was installed? or the pivot bearing not in right?
Old Apr 9, 2013 | 06:59 PM
H.R.D's Avatar
Single disk clutches are going to have a rough engagement when they are rated for higher HP.
Old Apr 10, 2013 | 09:42 PM
so what good does the hd hydrolics do since i have a hi end clutch and my stock hydrolics still seem to do nothin different then what the hd will do
Old Apr 12, 2013 | 11:15 AM
94 12valve's Avatar
they make driving a dual or tripple disk clutch much better
06dodgecummins
Jul 13, 2015 11:24 PM
broncobo43
Jun 28, 2015 08:32 PM
wannadrag
May 25, 2015 03:07 PM
Mar 27, 2015 07:20 PM
Sophia'sJustice
Mar 5, 2015 04:06 PM
