Low boost/Low egt
Old Apr 5, 2013 | 09:26 PM
blueroc's Avatar
Default Low boost/Low egt
2001 cummins/edge juice/ 80hp injectors/ fass95/ southbend clutch and hydros....
Normal= 36lbs boost,1400 egt.
Now=26lbs boost,1000 egt
Edge was sent in and updated as I thought that might be the problem,,
Built boost leak tester and everything seem fine
Cleaned all connections of the juice a couple times
Truck has been scanned.. no codes on the injection pump
map sensor is reading fine
Anything that im missing here..
My last 2 ideas are frozen wastegate( although I don't have excessive smoke)
or my vp44 just cant keep up
let me know if theres something else I should check
Old Apr 5, 2013 | 10:50 PM
How's fuel pressure?
Luke
Old Apr 5, 2013 | 11:49 PM
blueroc's Avatar
14@ idle 11@ wot
new filter
monitored from edge
Old Apr 6, 2013 | 12:14 AM
H.R.D's Avatar
Clamp off your your wastegate and see if that does anything for you.
corksil
Aug 2, 2015 10:19 PM
soco
Jul 27, 2015 06:06 PM
Noodle
Apr 21, 2015 06:43 PM
robbyS
Apr 16, 2015 02:22 PM
Brappp306
Mar 29, 2015 08:54 PM
