"Water in Fuel " light on - how to drain water from fuel filter on 96 GMC 6.5? Help..
Old Apr 5, 2013 | 03:38 PM
klein444's Avatar
Default "Water in Fuel " light on - how to drain water from fuel filter on 96 GMC 6.5? Help..
I have noticed that when I start my truck, 96 GMC K3500, the "Water in Fuel" light comes on and will stay on for about 1 minute before turning itself off. I never saw that light in my 97 Burb' - in fact I did not think we had the ability to drain water from the 6.5 fuel filter set up.
I owned a 03' 7.3 Powerstroke that had a specific water drain valve and a short piece of hose to drain the water.
What/how is the process of draining water done on the 6.5?
Do I need to drain it since the light does not stay on?
Any and all help on this topic is appreciated.
Thank you!
~GOD BLESS~
john
Attached Thumbnails "Water in Fuel " light on - how to drain water from fuel filter on 96 GMC 6.5? Help..-gmc3.jpg   "Water in Fuel " light on - how to drain water from fuel filter on 96 GMC 6.5? Help..-lucy1.jpg
Old Apr 7, 2013 | 06:47 PM
racer55's Avatar
Very near the thermostat housing is the WIF drain Tee valve,with the engine running open that valve-water comes out on the ground first then fuel-close it when clean fuel comes.
Might want a bucket under the end of the hose or pull it up and drain into an empty container.
Old Apr 8, 2013 | 10:48 AM
klein444's Avatar
Excellent - I drove the truck today and will look for the T valve. Is that the same one you open up when you are running the engine and you want to see if the lift pump is working?
~GOD BLESS~
john
Old Apr 8, 2013 | 07:32 PM
racer55's Avatar
The very same one.
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
yams
Dec 7, 2014 12:51 PM
