Still leaking
Old Apr 4, 2013 | 12:51 PM
85LARIATWA's Avatar
Default Still leaking
We have an 1985 Ford Lariat With 6.9 the only mod is after market turbo, this is a father son project that is also a daily runner. We have rebuilt this engine and are still trouble shooting some problems, the biggest one is the leaking of fuel around the injectors, we have installed an injector kit so all the o-rings are new as well as hoses and clamps, could there be to much pressure in these lines? All indications from other forums say the engine would not run or run rough if this we're the case, but she runs sweet. Thank You for any suggestions.
Old Apr 4, 2013 | 06:47 PM
j johnson's Avatar
did u lube the o-rings before you put it back together ?? they could have torn hence the leaking... scott
Old Apr 4, 2013 | 07:19 PM
RanchhandTCR's Avatar
What johnson mentioned you should lube the orings with vasaline or even motor oil so you dont roll the o ring or tear it.
Old Apr 4, 2013 | 10:33 PM
85LARIATWA's Avatar
Yes I did lube them so they would slide on easy, I keep a tube of Vaseline for just such an occasion, thank you for the response.
Old Apr 13, 2013 | 06:24 PM
85LARIATWA's Avatar
Ok so this problem is solved, I purchased another kit and did it all over again, the first kit had misfitting o-rings, they were to large. I tore it all apart twice and it still leaked so I decided to get another kit, this one was built a little different and the o-rings fit tighter, I had bought the first kit online, the second from a local parts dealer? thanks for the suggestions!
|WYG|SS
Apr 28, 2015 03:59 PM
bryan0702
Mar 18, 2015 05:03 PM
dieselpowa
Feb 7, 2015 10:07 PM
Stox5225
Nov 18, 2014 01:04 PM
WickedEvo
Oct 20, 2014 10:50 PM
