Fuel Shutoff Solinoed
Old Apr 4, 2013 | 07:05 AM
Pineknot23's Avatar
Default Fuel Shutoff Solinoed
Hello everyone. I figured I would throw this out there & see that hopefully get some answers
1994 12 Valve / bone stock never tweaked It or hopped it up. For some reason after I put (3)
Solenoid's on this truck over the past 7 or 8 years they stop working this last one is only a year
Old. You have to open the hood & pull up on it to make stay. I was gonna just throw a toggle between it & the battery. For some reason I'm not getting any juice to the switch. Plus it takes a few seconds for it to die with key in hand...
& the cruise doesn't work. Hasn't worked in a long time/ I've took it to my local mechanic he gets it working for a short time.
Not a Daily Driver/ just an ole fixer upper or Back up truck.
Thanks.
Old Apr 4, 2013 | 12:40 PM
daveO's Avatar
If your starter contacts stick, it will burn up that solenoid pretty quick. There's also a fusible link inline there that burns up at 65 amps. I got a new solenoid from Larry B. Here's his site:
LarryBs.com Dodge
On edit: There's also a relay in there that can be causing you problems.
Old Apr 4, 2013 | 04:21 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
are you talking fuel shut off or starter.
Old Apr 4, 2013 | 08:07 PM
Pineknot23's Avatar
Ok thanks!!! I'll check out the fuse link & the Relay both out; if the starter has anything too do with it would it still crank right up & sound normal or would drag?????
@ Diesel Pap it's the Fuel Shutoff Solenoid stops working!! Hasn't worked in a long time. The alternator quit charging; the fuel shutoff quit working & the cruise quit working.!! One of the mechanics told me it was the computer. He sent it off to be redone because they told him they were outdated & didn't sell them any more so they were going too rebuild mine; then they said they couldn't do it.
So I put the old one back in!!!!
He done something & re- routed some wires & put something in there to make the alternator charge again.. Now I just have the fuel shutoff solenoid (FSS) & cruise control to try & fix.
Old Apr 5, 2013 | 04:40 AM
97cummins's Avatar
The ecu has nothing to do with the issues your having for a 12 valve.
Old Apr 5, 2013 | 07:44 AM
diesel pap's Avatar
you can put a cable on the shut down.
Old Apr 5, 2013 | 12:11 PM
Pineknot23's Avatar
A cable!!???
You mean like a throttle cable??!!
Go mechanical instead of electrical??!!!
The ECU thats what it was!!!
Well that's good. One less thing to worry with; sounds like y'all got me going in the right direction to the root of the problem!!!!
Ill re check everything when I get back home.!!!
Thanks again everyone.
I'm sure I will be re-posting or replying in a month or so..
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
