temp guage pegged at 230?
Old Apr 3, 2013 | 08:20 PM
dom1505's Avatar
Default temp guage pegged at 230?
So I went to pull apart my dash in order to fix my 4 wheel drive light now I just have a new now I just have a new problem there was a wire or cable looking line behind the dash the only part that stays connected when you go to pull the dash out it seems as though there's a clip on there that broke I took a zip tie and got the part in the place it seemed to be originally except the temperature gaug which is pad tha at which is pegged at 230!!! I tried to mess with it some more but I had no luck idk if the cable has anything to do with it but it worked before and now I'm clue less any help would be great thanks
Old Apr 9, 2013 | 10:36 AM
dom1505's Avatar
Come on guys I need some help here I can't get it figured out I checked my temp sending unit, and the board in the guage cluster both ok!?!?!
By the way this is a 98
Old Apr 9, 2013 | 10:41 AM
MillerBoyzDiesel's Avatar
so the light comes on and stays on all the time?
Old Apr 9, 2013 | 02:55 PM
geddy's uncle's Avatar
I bet your temp guage pegged at "WTFH!" is just because it's no longer grounded. find its ground and reconnect
Old Apr 15, 2013 | 11:34 AM
dom1505's Avatar
No light comes on just the guage is pegged at hot I think it may be ground or the guage it self I'm guna install a mechanical guage better readung anyway and won't have this problem again
doodieroot
May 10, 2015 11:48 PM
emilio2496
8
Jan 13, 2015 05:03 PM
mule97
Dec 12, 2014 05:05 AM
