diesel start up sequence
Old Apr 2, 2013 | 07:40 PM
james2562's Avatar
Default diesel start up sequence
I have two diesels. When I start either of them the volt meter reads 12.x volts. then some time after ideling the engine makes some sounds like it is doing something and the volt meter reads 14.x. My powerstroke actually chokes and dies some times during this change over. It seemes to me like the alternater turns on after a warm up period.
Can someone tell me what the engine is doing?
Old Apr 2, 2013 | 07:57 PM
Mayhem's Avatar
the altenator is running at all times the engine is running I suspect that the glow plugs a cycling until there is sufficent heat in the engine as mine does the glow plugs pull alot of volts during this process
Old Apr 2, 2013 | 09:10 PM
james2562's Avatar
I thought the glowplugs were only on during the initial firing up of the engine and only for a few seconds at that. That once the engine was going, cold hot or otherwise, the glow plugs shut off. Was I wrong?
Old Apr 2, 2013 | 09:24 PM
MontanaTechPetroleum's Avatar
If the diesel is "cold" then the glow plugs with flicker on/off to keep engine running, mine does it all the time.
ish1521
Aug 26, 2015 08:42 PM
ebg2g
Mar 29, 2015 06:15 PM
irozchris
Mar 14, 2015 11:16 PM
shawnecarter
Jan 11, 2015 03:19 PM
shawnecarter
Jan 7, 2015 05:54 AM
