turbo code
Old Mar 21, 2013 | 02:13 PM
gordiejohnstone's Avatar
Question turbo code
i have a 2007.5 3/4 ton cummins with the egr and dpf deletes done and this morning my check engine light came on so when i got time i hooked up my smarty Jr to check and clear the code and it came up as "P2262-turbocharger Boost Pressure Not Detected - Mechanical" is this some thing i should be worried about?
Thanks
Old Mar 21, 2013 | 02:39 PM
MillerBoyzDiesel's Avatar
is the turbo working normally? usually the acuator hangs up and sets codes. The dealer used to have a cleaning kit they would use on them. I think most have done away with cleaning because it was only around a 20k mile fix before they had to do it again. I think most are just replacing the turbos now. Best thing to do to keep it from hanging up is delete egr which you have already done and to use the exhaust brake almost all the time.
Old Mar 22, 2013 | 09:43 AM
the turbo seems to be working normally, i haven't been using the exhaust break too often but i will put it on and see how it goes.
thanks
avatardvr
18
Aug 8, 2019 12:38 AM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
