FCA MOD FAIL!
Old Mar 18, 2013 | 07:52 AM
z71havinfun's Avatar
Default FCA MOD FAIL!
Attempted FCA mod. Leaked bad when reinstalled. Green oring flattened. Had a bag-o-orings I had in my box from MULTIPLE ISX egr cooler replacements. One was close to the green one. Noticed black one seemed wore. I had the right diameter oring but a lil thinner. Now truck idles between 8-9.5K rail press. 1). Could the oring cause the fuel to be bypassing causing high psi. It doesn't surge or lope but if you rev it up it drops in tween that range
2). Does anyone have/ know where I can get a modded fca or cheap non modded one.
3). Can I DD it for a couple days 12mi RT till I get parts or not recommended?
Update: filled fuel filyer with ATF and added a qrt to 1/2 tank. High idled for 45-60min. Idled back down to normal now its lower but stul 7.4-8.2k. Should i just run a 2stroke/atf mix for a bit and see if it was a sticky FCA? I did not have to force the plunger back into the sleeve but i did knick the sleeve pullin the cap off. But i smoothed it out and polished the sleeve? FML
Last edited by z71havinfun; Mar 18, 2013 at 07:52 AM. Reason: Automerged Doublepost
Old Mar 19, 2013 | 07:18 PM
Orings changed. Back down to 4.5. Pressures normal accept at WOT. HUUUGE difference. Recomend gettin new orings when doin mod but well worth the trouble.
coal_life
Aug 26, 2015 07:50 PM
Jul 30, 2015 08:00 PM
Jul 24, 2015 10:30 AM
May 17, 2015 12:10 PM
lineman71
Nov 24, 2014 02:07 PM
