Airdog2-165 and EJWA-cs install question.
Old Mar 15, 2013 | 04:25 PM
blairforce1's Avatar
Default Airdog2-165 and EJWA-cs install question.
Truck in sig.
Just finished up the new airdog 2 165 w/ quick disconnects. Open up my new ejwa-cs, read instructions and see it comes with a banjo setup for fuel pressure.
Wires to short to put sensor on airdog.
Whats my bbest bet here for the fuel sensor??
Thanks, Jim
Old Mar 15, 2013 | 09:37 PM
Bryce's Avatar
Check out Vulcan Performance. They carry a lot of fittings like this one Push Lock Fuel Pressure Tee 1/2"
Old Mar 16, 2013 | 08:45 AM
RAW's Avatar
RAW
I like to see the fuel pressure sender at the inlet for the VP44. The closer to the inlet, the better, IMO.
Old Mar 16, 2013 | 08:55 AM
Thats my dilema. I could easily make an extension wire to reach the airdog. Just not sure if thats going to be the same or real similar number to one i would get under the hood closer to the vp44. Then again i hate to cut the brand new quick connect line if i dont have to.
Old Mar 16, 2013 | 08:58 AM
RAW's Avatar
RAW
How are you plumbing your AD? Direct tot he VP44, or into the factory fuel filter? There are many options available for fittings and adapters.
Old Mar 16, 2013 | 09:31 AM
I plumbed it direct with the kit i got. It came with a quick connect fitting to go right in vp44. Then i opened the edge and it comes with a different banjo style fitting for vp44.
Old Mar 16, 2013 | 03:10 PM
RAW's Avatar
RAW
Not familiar with the quick connect you are referring to. I've only seen them with JIC (AN) fittings into the VP.
You can do a tapped Banjo bolt:
Or the inline adapter like the one in post #2.
Old Mar 16, 2013 | 03:28 PM
ricet07's Avatar
RAW, they are a "snap" or "push lock" style connectors that snap onto the fitting supplied and can be released by squeezing the tabs on connector head.
Your fuel pressure gauge should have a sending unit with 1/8" NPT what i did was cut the 1/2" fuel line that is supplied with the AirDig and used the T fitting like Bryce supplied the link for. You can thread your sender into that T or thread a snubber in the T and then your sender into the snubber. Mine is T'd into the line about a foot behind the IP and you can throw some hose clamps on there to make it a little more secure if you want.
Old Mar 16, 2013 | 03:49 PM
Yeah, that banjo bolt came with the ejwa. Just wasnt keen on cutting the new hose. First time in forever i havent lost prime overnight. I do appreciate everyones input.
Old Mar 16, 2013 | 04:15 PM
RAW's Avatar
RAW
Oh, I know the fitting, no stranger to them at all. I've never seen them in a kit to attach the hose to the VP44. Either a JIC push lock fitting, or push lock banjo, direly on to the hose.
