Oil leak drivers side! Please help.
Old Mar 14, 2013 | 03:26 PM
Dallimjp's Avatar
Default Oil leak drivers side! Please help.
It's me again. I feel dumb starting a new thread right after my last problem was solved, but here goes. I noticed my truck (96 12v) was leaking quite a bit of oil while it was running. Once the truck was turned off it stopped. After looking around I found where it was leaking from. Name:  2013-03-14140919-1.png
Size:  714.6 KBCan anyone tell me why it is leaking from there? Is there supposed to be a hose or plug there? Mind you this is on the drivers side down by the throttle linkage. The photo was taken from the drivers side fender with the camera looking towards the radiator.
Old Mar 14, 2013 | 07:16 PM
Dallas Flywheels's Avatar
Timing pin is missing...
Old Mar 14, 2013 | 07:36 PM
ricet07's Avatar
94-98 Dodge 5.9L 12 Valve Cummins Replacement Timing Pin
there ya go
Dallimjp's Avatar
How bad (time, cost) is that?
Old Mar 14, 2013 | 07:39 PM
ricet07's Avatar
$14/5 min
Old Mar 14, 2013 | 07:54 PM
Dallimjp's Avatar
I'm guessing I get it from the stealership? Just out off curiosity, could this cause any performance problems?
Old Mar 14, 2013 | 08:12 PM
ricet07's Avatar
You could but i put a link in my first post to a site where you can buy the part, or go to the stealership if you would like. No performance problems it is simply a housing for a pin that is used to find TDC. You apply pressure on the pin and rotate the engine slowly until the pin pops into to hole on the cam gear giving you TDC.
Old Mar 14, 2013 | 08:17 PM
Dallimjp's Avatar
Thanks for the link. I'm just hoping to get it asap. But that is a neat trick, the way the timing pin functions.
Old Mar 14, 2013 | 08:25 PM
ricet07's Avatar
They are pretty good about getting parts out fast at PDP
Old Mar 16, 2013 | 02:19 PM
NEWBIE 98's Avatar
there is supposed to be a retainer for it too. The stealership will prolly make you wait a day too. If you are near a Cummins counter you could get it there as well. 30 % of the dealer charge.
