Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
head bolts/studs
Old Mar 11, 2013 | 05:42 AM
fireman-1781's Avatar
Default head bolts/studs
Does anybody know the difference between ARP2000 head studs and the custom age head studs? Is there a big enough difference to justify the cost difference?
Old Apr 1, 2013 | 06:49 PM
BBD Tech Support's Avatar
ARP2000 Head Studs are 220,000 psi tensile strength
ARP custom Age Head Studs are 260,000 psi tensile strength. (For higher HP)
And price is the other difference
Old May 2, 2013 | 01:40 PM
Duramax_lly's Avatar
Have to tap the block for the bigger studs I'm pretty sure.
Old May 2, 2013 | 02:34 PM
MillerBoyzDiesel's Avatar
Theyre not bigger just different material. If you have an unlimited budget the customs will add some extra insurance but, Ive seen the regular 625's hold up just fine in compound setups and other various high horsepower applications.
Old May 3, 2013 | 01:24 AM
2004LB7's Avatar
I believe your are just chasing the bottom few threads to take advantage of them. This would be done with a bottom tap as GM uses a taper tap and the last few are not complete
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
Vmason
Jan 21, 2015 11:33 PM
Adam65
Jan 9, 2015 11:50 PM
Oct 31, 2014 08:10 AM
