Front end issues
Old Feb 27, 2013 | 05:09 PM
cummincider's Avatar
Default Front end issues
My front end was clicking real bad when I would turn the wheel far right or left I unplugged the front end vacuum and it turns a hell of a lot better but know its shaking in the front and when I hit the brakes it stops Im thinking I have bad bearing in the front and I filled up the front end and it's leaking behind the actuator and the front seal of the axle so I'm guessing bad bearings and locked actuator am I on the right track plz lmk and all replies greatly appreciated also it's a 97 12 valve on 37s if that makes any difference
And the steering has been feeling sloppy
Anyone?
Bump
Last edited by cummincider; Feb 27, 2013 at 05:09 PM. Reason: Automerged Doublepost
Old Feb 28, 2013 | 07:54 AM
MillerBoyzDiesel's Avatar
Jack up the front end check for play in hub units, check frnt axle u joints for play. pull frnt actuator assy off and apply vaccum to ports one at a time and see if it moves correctly.
shingi
Off Roading
Sep 30, 2015 11:17 AM
tbirdz24v
Aug 22, 2015 06:41 AM
Slim Whitey
Wanted To Buy (WTB) - Used
Mar 3, 2015 06:15 PM
2FordStrokers
Jan 11, 2015 09:40 PM
Cumminsman911
9
Nov 1, 2014 04:07 PM
