Need help deciding injector size! Help Rollin coal!
Old Feb 24, 2013 | 02:19 PM
Jackson91's Avatar
Default Need help deciding injector size! Help Rollin coal!
hey guys I have a 2002 dodge cummins with a cold air intake and a smarty sr chip with 4 inch exhaust and I'm going to put bigger injectors how big can I go without hurting the truck? I want the injectors mostly for rolling coal what's your thoughts on what I can do. Thanks in advance
Old Feb 24, 2013 | 03:02 PM
tiremann9669's Avatar
Just take a 1/16th drill bit and drill yours out cheap coal
Old Feb 24, 2013 | 04:34 PM
Jackson91's Avatar
I'm not down with the Niger rigging but thanks anyway. Anybody els have any suggestions for me please. Muchly appreciated
Old Feb 24, 2013 | 04:50 PM
1999stroker's Avatar
Yeah build your truck properly for horsepower and smoke will come. Noone in the diesel world likes guys coming around asking for just massive smoke blowing.
Sent from my DROID RAZR
Old Feb 24, 2013 | 05:05 PM
CR9712v's Avatar
check out some of the sites vendors man, you tell them your setup and theyll recommend the best injectors for quality and performance just for you
Old Feb 24, 2013 | 07:29 PM
shellinger's Avatar
this is just a personal opinion but if you are planning on dumping more fuel make sure you have a good lift pump to feed fuel to the vp44. i would get a fass or air dog system before the injectors unless you already have one. if not you can run the vp dry and possibly kill it. which means lots of money spent. and also you do not want to go to crazy on the injectors if you are still running a stock turbo. i personally wouldnt go over 75hp injectors on a stock turbo unless you are planning on upgrading the turbo in the near future.
Old Feb 24, 2013 | 07:37 PM
If you're referring to an African American it's "******"
Old Feb 24, 2013 | 09:50 PM
Mopar1973Man's Avatar
Here is what I got...
* Edge Comp
* RV275's
* AirDog 150
I've got enough power I can outright smoke 2nd gear and bark 3rd gear and do it completely smokeless (well just a slight small puff). I can careless for the smoke but I'd rather have the clean power and sleeper appearance. What's even more funny I still spin the tire even hitched up to the RV.
Old Feb 24, 2013 | 11:47 PM
Jackson91's Avatar
I don't care completely about smoke I just want lots of power and the most I can get out of sticks I staid of upgrading my turbo and lift bump atm so probilaly the highest I should put in is 100 hp sticks and as long as I watch my egts it should be okay right? I know smoke comes with power and I'm not all just for smoke but it would be nice to **** up tailgaters as I punch it when I want to, thanks for the replays appreciate it guys.
Instaid* and lift pump *
Old Feb 25, 2013 | 10:03 AM
jkidd's Avatar
bigger than 75HP and you will surely slip the clutch or converter. Do you have a lift pump upgrade?
