Cummins ford swap into v10 ford fuel system ???
Old Feb 19, 2013 | 09:30 PM
Buckshot927tx's Avatar
Default Cummins ford swap into v10 ford fuel system ???
hey fellow diesel lovers! i am wondering what pieces of the factory fueling system can be retained? can i use the factory fuel pump as a lift pump or no? or could i use them both together or would that blow right pass the factory cam bump mechanical pump? thanks a lot for any help
Old Feb 19, 2013 | 11:43 PM
deck60's Avatar
no you cant use the factory fuel pump too much pressure this is what i used works great
stock lift pump at 2200rpm 110 gph at 8psi
New 140 GPH Electric Fuel Pump | eBay
remove pump and put a piece of stainless line for your pickup with a stainless screen on the end I found a screen at napa that worked fine
Old Feb 20, 2013 | 06:37 PM
Thanks man, i pm'd you
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
