Deletes before warranty up?
Old Feb 18, 2013 | 09:11 PM
ShaineDTFD's Avatar
Default Deletes before warranty up?
Hey guys, I'm really considering doin the deletes on my 09 6.7. I've got around 64k miles on the truck. So roughly 30k left on the warranty. I'm just wondering if it is worth it to void the warranty on the truck to do the deletes. The general consensus so far has been yes because the truck will run better/ better fuel mpg and all the other stuff. Seeing as all the emission bs bogs the truck down and chokes the motor basically. If it's a good idea, what perticular deletes should I start with. I already planned on a 5" mbrp exhaust. But what programmers/tuners have worked best for yall with that. ALso, is there a better or worse egr delete kit I should go for/avoid?
Old Feb 18, 2013 | 09:18 PM
coors_man_2005's Avatar
sounds like your about 64k miles late get the crap off of it only warranty you will lose is you emissions warranty.
Old Feb 18, 2013 | 09:21 PM
ShaineDTFD's Avatar
See, im not a warranty guy. That crap means nothing to me. But I was told it voids the powertrain warranty.
Old Feb 18, 2013 | 09:35 PM
they can try but they have to prove that the deletes caused your problem
Old Feb 18, 2013 | 09:54 PM
EFI Live
Luke
Old Feb 19, 2013 | 01:21 AM
gunman41mag's Avatar
Moderator
My truck was having problems, so I did the deletes, no more problems, also tuners with deletes are no longer made, so better buy one quick before they're all gone
Old Feb 21, 2013 | 02:49 PM
cummins05's Avatar
H & S mini maxx with there delete kit worked great for me! Good luck finding them anymore though!
Old Feb 21, 2013 | 07:39 PM
ShaineDTFD's Avatar
So far what I'm going with. Haven't made the actual purchase yet until I know for sure it's what I want. But an aFe Mach Force XP 4" stainless from turbo back. (obviously with deletes. (MBRP doesn't have an actualy full system with the dpf delete, you have to part it out which I don't want to do.)) The Sinister Diesel EGR delete kit. The Smarty Jr. programmer with deletes, and the Edge Insight touch screen monitor.
Old Feb 21, 2013 | 08:04 PM
Buy full exhaust for 07 5.9 same thing and mbrp does make it just not as a dpf delte kit but it will bolt right to ur truck
Old Feb 21, 2013 | 08:09 PM
ShaineDTFD's Avatar
This is probably a really stupid question ( I'm polish, so it's natural), but the deletes will still have to be done in the ecm correct?
