2010 6.7 cummins Overheating...?
Old Feb 17, 2013 | 05:06 PM
missp24's Avatar
Default 2010 6.7 cummins Overheating...?
2010 6.7 dodge laramie Cummings. Has H&S EGR delete on it. Have not had any issues until I had this kit put on. Under a load the truck overheats, goes down 20 degrees goes back up. Trucks acting like its vapor locking. Has brand new turbo, new head bolts, new thermostat, new injectors, water pump. I can release the radiator cap and a ton a air and antifreeze comes out, the truck immediately cools off then as soon as I get back on the highway it's headed right back for 240+. I don't have any of these issues until I'm towing a load. Really confused on what's going on...someone here maybe had the same problem?
Old Feb 17, 2013 | 10:21 PM
coors_man_2005's Avatar
first lets start with the (cummins) no g. you have a blown headgasket. and i bet your overflow tank is full as well. and i bet your heater may stop working at times right? so im saying head gasket. your having all the tell tell signs
Old Feb 17, 2013 | 11:30 PM
missp24's Avatar
Yes autocorrect does suck at times . No the oil is clean, no water. Head gasket has been checked anyway. Just went through a major overhaul in that area. I am almost wondering if it has to do with my EGR delete and the coolant route on it.
Old Feb 18, 2013 | 06:07 AM
You can completly plug them lines off and it wont change a thing. I would lay money on it its your hg.
Old Feb 18, 2013 | 06:43 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
this is exactly how my 08 acted when i had a head gasket leaking.
Old Feb 21, 2013 | 03:47 PM
missp24's Avatar
Alright guys the head gaskets been replaced and is Still overheating. Dealership says they think it could be a cracked block or cracked cylinder??? Confused : /
*cracked head (not block)
Old Feb 21, 2013 | 06:08 PM
diesel pap's Avatar
did someone not deck the head and check for cracks
Old Feb 21, 2013 | 07:17 PM
griff44's Avatar
What tune are you running, When they did the gasket the head should have been magna fluxed for cracks. If it was ok the should of decked it and then put at least ARP 425s in.
Old Feb 21, 2013 | 07:37 PM
Just pressure test the head its a better deal. sounds like you have some idiots working on your truck if they didnt check.the head. IF it has had blown a hg. i will bet the head needs decked cause i bet its not close to being flat. As well a good machine shop to put the correct finish on the head the wrong finsh with the mls gasket could result in hg failure as well. Also be sure they check the block for being flat there short cutting or not paying attention to something
Old Feb 23, 2013 | 06:28 AM
charlie m's Avatar
Take a coolant psi tester, install it on your overflow tank run at 1200rpm for 1-2 min, if it spikes psi quickly you have a issue, crack or upside down HG
Rooster78
For Sale
Apr 2, 2015 06:35 AM
spredfern86
Jan 16, 2015 03:15 PM
Rooster24v
Price Quote - Request A Price
Dec 10, 2014 06:15 AM
jmed795
Oct 1, 2014 09:09 PM
