new swapper experianced modder
Old Feb 15, 2013 | 01:23 AM
RamminIt's Avatar
Default new swapper experianced modder
Hello, I am the proud owner of a 94 Ram 2500 V10. though i love the big engines, it has been my dream to own a turbo cummins diesel. I am at the mercy of guru swappers. Can i take my 94 ram and turn it into a diesel, the new motor has some hinks but ill fix them, but before i even buy t, the motor is from a 99 ram with a cummings turbo diesel. will that fit in my 94? both rigs are automatic.
what do i take from the other rig? everything? wires too? do i need to take the fuel lines? do i just take everything and swap it out? mighty swappers, grant me your wisdom! ( please?)
Old Feb 15, 2013 | 01:34 AM
jdbigblue12v's Avatar
The 99 ram is a 24 valve and will be more difficult to swap in. Also you need a diesel trans due to governor speed shift points. I would look for a 12 valve or maybe even p-7100 pump the 24 valve and do away with wiring on the vp-44 off the 24 valve.
Old Jul 15, 2013 | 12:33 AM
RamminIt's Avatar
it has been a long time since i got to update you guys. Due to problems with the irs the Conversion did not happen with that particular truck. I however started thinking, Could i drop the 24V cummings into my 1990 chevy suburban?
let me know! ill post pictures of the suburban so you can see what i am workin with.
Old Jul 15, 2013 | 08:58 AM
diesel life's Avatar
that you can do, but as stated before it would probably be easier to find a 12valve to swap in or p-pump the 24valve due to all the wiring needed for the 24valve electrinics to work.. the 24valve is an electronic controlled injected pump vp44 the 12valve is all mechanical.. A lot easier in my mind to do the 12valve but if you p-pump the 24valve it wouldnt be to bad just a couple extra thousand $$$$ good luck let us know what happens
Old Jul 15, 2013 | 10:24 AM
RamminIt's Avatar
I think i will have to take you up on that advice, a 12V would be just fine, as long as i could get atleast a twin on it. gotta keep the dream alive I'll let you know what i find!
Old Jul 15, 2013 | 11:16 AM
sounds like youve made up your mind let us know how the build goes and the results, hell you could start a build thread over in the show and tell or right here good luck
Old Jul 16, 2013 | 12:52 PM
RamminIt's Avatar
yeah, feels good to have the mental list of what to get all layed out, now to put into action. I am not to familiar with swapping engines in trucs, more so from gasoline to Diesel. i can pull an engine and rebuild the **** out of it, but i would be lying to say i am not at all nervous about the whole project.
