Show And Tell Got Photos or Videos of Your Diesel ? - Post Here and Tell Us About it , We Support Most Video Sites , Diesel Videos will Auto Embed .
2008 Toyota Tundra Diesel Dualie - 1-Ton Diesel Truck
Old Mar 24, 2008 | 10:30 PM
Diesel Bombers's Avatar
Staff Reporter
Information 2008 Toyota Tundra Diesel Dualie - 1-Ton Diesel Truck
It's been 15 years since Toyota brought the T100 (its first so-called "1-ton" truck) to the U.S. with just 150 hp under the hood. Since then, the truck evolved into the Tundra, which was considered by many to be a 9/10-ths scale model of a fullsize American pickup. Then, after years of testing our domestic market and taking over the compact truck segment with the Tacoma, the world's richest automaker decided to make the Tundra fullsize for 2007-and gave it dual rear wheels and an 8.0L Hino inline-six turbodiesel engine for the SEMA show.
Toyota Diesel Power
The massive 488-cubic-inch Hino J08E-TB turbodiesel in this Tundra is no Cummins, Duramax, or Power Stroke. It was designed for delivery trucks that haul with a GVWR of 35,000 pounds, and has a power rating of 260 hp and 585 lb-ft of torque without any modifications, which would be more than enough grunt to move the Tundra chassis along with a 20,000-pound trailer. Just like the engines in modern 1-ton diesels, the J08E-TB uses common-rail fueling, a variable-geometry turbo, an electronically controlled intake throttle, and twin EGR coolers to lower NOX emissions. Unlike the stock engines in the delivery truck applications, this one gets to breathe through a free-flowing 4.5-inch Magnaflow exhaust that reduces EGT while towing, and sweetens the sound whenever the Hino is fired up.
5-Speed and HD Axles
To deal with the torque of the large displacement diesel, the Toyota Motorsports Technical Group drastically modified the drivetrain. A heavy-duty Eaton 5-speed manual is used to transmit the massive amounts of torque from the engine back to a Meritor axle that uses "Hypoid-Generiod" gearing for strength and quiet operation, plus it can be equipped with a remote-actuated locking differential.
Custom Suspension and 24K Hitch
Support for the heavy diesel engine in the 1/2-ton Tundra frame comes from a front suspension setup with custom dual front struts with Bilstein shocks. To provide a stable home for a Reese Signature Series 24,000-pound fifth-wheel trailer hitch in the bed, a Deaver spring pack and Bilstein shocks replaced the stock Tundra rear suspension.
22.5-inch Dual Rear Wheels
To make the Tundra look like a true 1-ton truck, a 6.5-foot bed was fabricated with fenders for dual rear wheels, and 22.5x9-inch 10-lug Alcoa brushed aluminum rims were mounted at all four corners, along with large drilled brake discs up front. The wheels are wrapped in Michelin XDA 2+ Energy 295/60R22.5 tires that have strong sidewalls for towing and are designed with low-rolling resistance to maximize the dualie's mpg.
Mad Max Paint and Hand-Sewn Leather
SEMA trucks have to look good to get any attention at the annual aftermarket parts show, so the Toyota Motorsports Technical Group decided to use what it calls a "Road Warrior" exterior theme, along with a luxurious interior. The menacing look is due in large part to the Matte Charcoal Metallic paint that makes the Tundra look like it could be used to transport a SWAT team. Low-profile LED clearance lamps are recessed-mounted into the dualie fenders and the tailgate, and a set of four PIAA P-4000 Quattro driving lights are mounted on top of the cab to make sure the Tundra diesel is always seen. The exterior of the truck was also upgraded with generous helpings of diamond plate lining the entire cargo box and AMP Research powered running boards. Other exterior touches include bright satin brushed nickel on both bumpers, the grille surround, telescoping trailer mirrors with built-in turn signals, and dark brushed Tundra emblems.
The interior also had to be up to SEMA standards, so everything was wrapped in ginger leather with French stitching, a matching suede headliner was installed, and satin brushed nickel can be found on the AC controls, door handles, and other trim pieces. To complete the interior, a Kenwood touch-screen DVD player and navigation system with dual rear-seat entertainment was installed along with Kenwood speakers and amplifiers.
'09 Toyota Tundra Dualie Diesel?
So, does this mean that you'll be able to walk into a Toyota dealership later this year and drive home in a Tundra dualie with a turbodiesel under the hood? Probably not. This truck was built for SEMA to gauge customer interest in oil-burning 1-ton Toyotas here in the U.S.A., but it's far from a production vehicle. Toyota took a decade and a half to make the jump from midsize trucks to 1/2-ton pickups, so we don't expect them to jump into the diesel deep end of the fullsize truck market while the domestics are still figuring out how to meet the new EPA regulations that are going into effect. After the strict 2010 rules become law though, we won't be surprised if Toyota looks at Chevy, Dodge, and Ford and says, "Game on!"
Photo Gallery: 2008 Toyota Tundra Diesel Dualie - 1-Ton Diesel Truck - Diesel Power Magazine
Read More | Digg It | Add to del.icio.us
More...
Old Mar 24, 2008 | 10:48 PM
Uncle Bubba's Avatar
May as well get the new section ready cause this thing is mine, some day when I can afford it.
Old Mar 24, 2008 | 10:49 PM
Benjamin's Avatar
Bombardier
i'd for sure drive the crap out of that.....
Old Mar 27, 2008 | 01:21 PM
LOGANSTANFORTH's Avatar
i have thought about it, wait til someone builds one, 8 liters is ALOT of cubes to push ALOT of fuel and air into, it will soon dominate......
Old Aug 16, 2009 | 11:55 PM
Give Me Diesel's Avatar
screw that go american. we really need it.
Old Aug 17, 2009 | 01:25 AM
Toyota has more American employees then any other Auto Dealer out there.
Old Aug 17, 2009 | 01:30 AM
stkdram55's Avatar
yeah but thats not the point...still after everything is said and done the money goes over seas
Old Aug 17, 2009 | 01:31 AM
That's a political debate I won't touch.
Old Aug 17, 2009 | 01:35 AM
stkdram55's Avatar
ok...sounds good to me
Old Aug 17, 2009 | 06:33 AM
Mr. Miyagi's Avatar
Yeah, buy American trucks, built in Mexico, with Brazilian built powertrain, because the money ends up back here to do what? Hell, I dunno either since 2 of the 3 automakers based here are f'ing bankrupt...they have nice planes, though...
I laugh my *** off when people spout "buy American".....and use the "well the money ends up back in Japan" defense to Japanese companies building a superior product here with an American workforce.
You ever check out the Federal Trade Commission reports, and the Federal Reserve statements regarding which countries in this world are underwriting our debt so we can act like **** of the walk? You'd wish it was Japan.
And please, no rhetoric about Japan. My grandfather flew planes in the Pacific during WW2, and was in charge of training the Japanese forces to take over the Pacific radar grid when we gave them Okinawa back as part of the surrender agreement, and he drives a Honda Civic hybrid and Toyota Tacoma 4x4 with pride. If the **** is good enough for him, it's surely good enough for any of us...
How 'bout that computer you're typing away on? Or the cell phone? How 'bout the TV? Or the microwave?
It's old news....get off it already.
That truck, if Toyota ever decides to build it, will be built most likely here in the U.S., unfortunately. If it was 100% made in Japan it would be even better. I would dump my F350 in a heartbeat to get one.
