axle shaft help!!
Old Feb 2, 2013 | 03:06 PM
vinnie0104's Avatar
Default axle shaft help!!
Not sure if it is just me or not but i can not get the front axle shaft out. I am changing my ball joints and need to get the axle shaft out. I have never pulled it since ive had the truck, so not sure when the last time they were out. If anyone can help me i would greatly appreciate it
Old Feb 4, 2013 | 02:15 PM
steved's Avatar
If you have the unit bearing off, then it will come out...the seals tend to make them stick, and you may need a bar to get it started...it should sort of pop then slide right out.
Old Feb 4, 2013 | 04:28 PM
NadirPoint's Avatar
Putting them back in is the tricky part. If you're not careful with the seals you'll be pulling it apart again to replace the seals.
Old Feb 6, 2013 | 11:45 AM
vinnie0104's Avatar
I appreciate the help. It was a long day and late when I started pulling everything apart. It was in there good. I pryed it out and was good to go
Natenelson1
Jan 19, 2015 07:23 PM
Dec 19, 2014 02:30 PM
natenel1
Oct 26, 2014 03:09 AM
94cummins12v
Towing and Hauling
Oct 21, 2014 02:50 AM
blakec
20
Oct 18, 2014 03:35 PM
