Towing and Hauling Diesel Discussions of Towing and Hauling Practices , Techniques , Tips Including Trailers , Campers , 5th Wheels , Goosenecks , Boats and More
Trailer weight ???
Old Jan 29, 2013 | 05:15 PM
mesjr's Avatar
Default Trailer weight ???
Well , I'm in the market for a new horse trailer with living quarters . Problem I have a 06 dodge 2500 . I've hooked to a trailer that was too much for my truck . Problem is I have no idea what it weighed . But the trailer I want weighs 8600 with a16800 grose and a estimated 2800 pin weight . I don't want to spend 50k on a trailer and have to replace my truck. From the research I've done I think 90% of the trucks hooked to trailers are overweight, and seems almost stupid to even offer a 3/4 when payload of 1 ton srw is only a few hundred pounds . But can my truck safely handle this trailer , I know factory weights are really consertave otherwise everyone pulling trailers would be using tractors
Old Jan 29, 2013 | 05:39 PM
Prozach's Avatar
I pull my 3 horse GN with LQ's with my old 96 12v. my truck and trailer empty weights 15,135 pounds. with my three horses and tack/hay I was at 18,985. The old dodge had no issues.
Old Jan 30, 2013 | 08:55 AM
mesjr's Avatar
The gvwr of the trailer alone is 16800 empty trailer weighs 8600 . So truck and trailer empty is around 17000 ?
Someone has to have some input . Is 2800 lbs too much pin weight ? That's my main concern
Old Jan 30, 2013 | 10:03 AM
RAW's Avatar
RAW
What axle ratio do you have? With 3.73's, it may be close if not over what the rating is. With 4.10's, you should be fine.
What load range are your tires? If you have E tires, they will hold up fine.
E tires, Air Bags, the proper trailer brake controller, hook on and GO!
Old Jan 30, 2013 | 01:10 PM
mesjr's Avatar
373 ratio . E rated tires , no airbags . I don't have a problem w bags I just don't want to put them on and still have the tail wagging the dog so to speak
Old Jan 30, 2013 | 02:01 PM
RAW's Avatar
RAW
Tail wagging on the dog?? That's a new one to me.
As long as your 5th wheel connection point is lightly ahead of your rear axle, it should pull nicely.
Old Jan 30, 2013 | 02:11 PM
Prozach's Avatar
What Wheel base is your truck? You would only get Tail wagging if you dont have enough tongue weight, or you are trying to pull too big a trailer with too small a truck.
Old Jan 30, 2013 | 02:22 PM
mesjr's Avatar
4 dr sb . I've hailed some heavy stuff but always bin able to move the weight around on the trailer . Not an option with horse trailer .
Old Jan 30, 2013 | 02:26 PM
Prozach's Avatar
My step mom has a 2004 or 5 CC short. She has a Featherlight 3 horse with LQ. Only problems she has is that the trailer is 8ft wide so she has to use the B&W trailer neck extender to set the trailer back so she can turn.
Old Jan 30, 2013 | 04:10 PM
mesjr's Avatar
Prozach how long is her short wall?
