2004 New to me...needs help
Old Jan 26, 2013 | 09:44 PM
Gatorm's Avatar
Default 2004 New to me...needs help
Just bought a 2004 5.9 and it starts and idles fine but when I touch the pedal it revs what seems like to redline and the limiter catches it and it goes up and down, up and down, up and down. I bought it this way so its not a surprise to me but I gotta fix it. Before I take it somewhere are there any things I need to check. I am a long time powerstroke guy (ducks to dodge the rocks being thrown) so i am new to this engine. I am eager to learn about the cummins. Been a long time aircraft mechanic so I should be able to learn my way through this thing in time. Thanks for having me here guys...looking forward to the help.
Old Feb 1, 2013 | 05:57 PM
Willy Muhr's Avatar
Pull the injectors and have them bench tested.
Not much need to do any run around and parts swapping bc that is more than likely the issue, or maybe try to run some injectors cleaner or trans fluid through a couple tanks and see if it helps at all
Old Feb 1, 2013 | 06:21 PM
H.R.D's Avatar
Could be the TPS (Throttle Position Sensor)
Old Feb 1, 2013 | 08:53 PM
dangerous1965's Avatar
Contact Todd at T&C diesel tell him Andy CA sent you! Could be a PRV or CP3 issue! Google him!
Old Feb 5, 2013 | 03:25 PM
Gatorm's Avatar
It was FCA. Thanks for the help
JaysTruck
Jul 22, 2015 11:49 AM
carmel
Mar 20, 2015 09:25 PM
MFARRENS
Jan 27, 2015 07:35 PM
Alwaysgone
Jan 21, 2015 04:55 PM
PerformanceAuto
Jan 15, 2015 12:32 AM
