Fuel Leak
Old Jan 23, 2013 | 11:41 AM
TNich's Avatar
Default Fuel Leak
I've got an 03 F-250 with the 7.3L with 307K on the odometer. Today at work I noticed a small puddle under the engine, when I checked it was fuel. I've been told that with higher mileage diesels some leaks are common. I just do normal driving and occasionally will pull a horse trailer or my kids marching band trailer with it. Where would the most common spots be should I check to make sure that there isn't a serious leak. I run the occasional lucas oil fuel additive through every few tanks since I bought it last spring. The oil looks good and I'm not noticing any other problems. I'm a single dad of three teens on a budget so I want to save this from becoming a big/costly fix if I can. Any advice/help would be appreciated.
Old Jan 23, 2013 | 03:01 PM
j johnson's Avatar
check around the fuel filter..were the fuel lines connect
Old Jan 23, 2013 | 05:53 PM
TNich's Avatar
I noticed some fuel under the fuel filter. I had the truck running but can't see any fuel leaking out. I couldn't tell by looking if anything was loose but I also am not very flexible and couldn't get my hands in there.
Old Jan 28, 2013 | 05:28 PM
l_stehling's Avatar
Im a dodge guy now but drove 2 7.3s in high school. I had common peoblem of them leaking at the water drain valve on the fuelfilter housing. I guess there an o ring in there that wears out. That valve runs bout 50 bucks I think. 4 small screws that attach it to fuel filter housing. Should be able to see it leak when running with flashlight have to look close. Hope this helps
Old Jan 29, 2013 | 06:58 AM
TNich's Avatar
I'll take a look, thanks.
Dale9411
Dec 4, 2022 06:51 PM
Dbleo351
Nov 20, 2016 09:34 AM
moneypitk5
Feb 12, 2015 11:01 AM
4x4kingx889
Jan 25, 2015 02:02 PM
Dec 5, 2014 08:30 AM
