2001 2500 hd
Old Jan 23, 2013 | 07:00 AM
Rodney Jenkins's Avatar
Default 2001 2500 hd
Hey guys need help please, i know my injectors are bad and need replaced. What happpened is i got up to go to work monday and 60.00 worth of fuel drain out somehow and all oil leaked out. I took plug out of the oil pan and found a gal of diesel in oil pan and small silver metal shavings and ideas on whay caused this? Thanks
Old Jan 26, 2013 | 02:21 PM
Red_Rattler's Avatar
High Tech Redneck
Sounds like that motor is trashed... Lack of lubrication from fuel dilution will cause oil to leak from many places being burn or pushed out of the exhaust and ventilation tubes. You probably just cost yourself 10k in repair bills
Old Jan 27, 2013 | 11:18 AM
carlc's Avatar
U MUST HAVE A FUEL LEAK IN THE ENGINE IF U GOT FUEL IN UR OIL
Old Feb 7, 2013 | 11:02 AM
FSS Diesel's Avatar
If your injectors are bad you might of had one of the return lines start leaking, which will fill the crankcase with fuel which drains into the oil. Then with that happening for a time that will cause all types of problems.
Old Feb 19, 2013 | 02:13 PM
perkinsd_theone's Avatar
I'm leaning with the fact you say there are metal shavings in the oil that you prolly put off that injector job too long, injector cups leaked fuel into crankcase, and engine has pooped the bed from oil dilution.
let us know.... I'm interested..
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
John Sutton
Aug 24, 2015 04:12 PM
nelly559
Feb 2, 2015 08:19 AM
Dec 29, 2014 10:20 AM
sulfurburner
Oct 17, 2014 12:46 PM
