A few questions boys....
Old Jan 22, 2013 | 08:58 PM
angelic0-'s Avatar
Default A few questions boys....
So, i'm looking at installing a set of 7x.014s ?
With my Pump MAXED OUT.... and the rest of my setup...
I was calculating that i could possibly be making 90psi (6.2bar?) boost and POSSIBLY make 900crank HP... but they would be HOT HP...
I'm thinking this is possible, HX60 should be able to supply for 1000WHP as a single... 92mm inducer....
My HX40 is a Super 40 16cm2 wastegated...
Any suggestions, other than a new clutch setup ?
Old Jan 26, 2013 | 02:24 PM
Red_Rattler's Avatar
High Tech Redneck
studs oringed head better valve springs and pushrods more crank case ventilation are some off of the top of my head
Old Jan 26, 2013 | 06:35 PM
12vcummins96's Avatar
^^^ what he said
Old Feb 3, 2013 | 12:26 AM
EasternAggie's Avatar
7x.014's aren't enough for 900 crank HP. What HP level do you want to be at?
Old Feb 3, 2013 | 09:06 AM
angelic0-'s Avatar
750whp street is what i'm shooting for
Old Feb 3, 2013 | 09:21 AM
geddy's uncle's Avatar
you will need more tires
Old Feb 3, 2013 | 09:23 AM
angelic0-'s Avatar
I know
Old Feb 3, 2013 | 01:27 PM
I take back what I said earlier; 7x014's actually have a cross-sectional area of .001077, comparable to a 5x.016 at .001005. But, most major injector builders still prefer 5 hole injectors over 7 hole. I think 5x.016's or 5x.018's (.001272) should suit you well.
mike71800b
Aug 18, 2015 03:50 PM
Mar 20, 2015 08:20 AM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
