Po237 Super boost input voltage low Throttle response intermit
Old Jan 18, 2013 | 08:42 PM
00cummins3500's Avatar
Default Po237 Super boost input voltage low Throttle response intermit
2000 3500 Edge comp box FASS 150 5 inch exhaust
Getting po237 code super boost voltage input low is what my scanner reads the code is intermittent. Also having throttle response issue sometimes when taking off from stop truck is a turd then will intermittently take off then slow down with steady hold on pedal. Are these issues related put two new batterys in also new map sensor. thanks guys
robbyS
Apr 16, 2015 02:22 PM
