front axel u-jiont HELP!!!!!!!!
Old Jan 18, 2013 | 02:21 PM
paxlaser's Avatar
Default front axel u-jiont HELP!!!!!!!!
I finally got the truck in my garage to shoot some electrical problems but I thought I'd tackel a bad u-joint first. Now I'm stuck. I have the front end on jacks. Removed the four bolts from the front drive shaft flang that connects to the transfer case but the drive shaft is stuck. I expected the drive shaft to drop right out but its tight. How to I get the drive shaft out? Do I need to remove ther rear drive shaft also? All I want to do is replace a lously $15 u-joint! I have been at this for 3 hours! 2004 ram 2500. quad cab....
Old Jan 18, 2013 | 02:57 PM
IH340Greg's Avatar
Put a pry bar between the yoke and the u-jont
Old Jan 18, 2013 | 05:19 PM
paxlaser's Avatar
Thats all?
I'll give it a try but it seems like I' going to break something
No joy. It wont move at all. Should I remove the front bolts that go to the diff?
Originally Posted by paxlaser
Thats all?
Just put the bolts back in. I'm going to wait untill next weekend and try it again
shingi
Off Roading
Sep 30, 2015 11:17 AM
carid
Diesel Bombers Sponsors
Aug 11, 2015 06:24 AM
Natenelson1
Jan 19, 2015 07:23 PM
gyayo2012
Nov 15, 2014 08:11 PM
