Towing and Hauling Diesel Discussions of Towing and Hauling Practices , Techniques , Tips Including Trailers , Campers , 5th Wheels , Goosenecks , Boats and More
drop hitches
Old Jan 18, 2013 | 12:13 PM
countryboy51's Avatar
Default drop hitches
been looking around for a 10in drop hitch rated a 10,000lbs. not really finding anything. seen some adjustable ones but not sure if its worth the price? anyone have any suggestions?
Old Jan 18, 2013 | 10:38 PM
junkyardkid69's Avatar
build your own
Old Jan 18, 2013 | 11:09 PM
Truck Guy99's Avatar
My dad and i have used adjustable drop hitches for years and they are worth the $130. Never buy another hitch and save money in the long run. Just get the one from tractor supply. If you aren't near one, order it online from the website. Only complaint is it's heavy. But if you remove 3 pins, it dis-assembles and is much lighter. Pay now or pay later.
Old Jan 19, 2013 | 02:34 PM
tiremann9669's Avatar
Got mine at tractor supply for $80 cant remember if it's 8" drop or 10" , I'll have to measure and report back.
Old Jan 21, 2013 | 06:40 AM
i did build one and i also seen the one a tractor supply and rural king..only 8in drop. already got a 8 inch need a 10 for my new trailer. also i dont think the adjustable ones there are rated for 10k
Old Jan 22, 2013 | 08:53 PM
Our adjustable one came from tractor, but it's a solid type. It is not a piece of square tube. It is a solid chunk. We once pulled 19k on it. Still use it to this day. The 2 5/16 is rated for 10k. A duplicate wouldn't be hard to make. Sounds like a project in the works!!!
Old Jan 22, 2013 | 11:37 PM
Yea there's cheap adjustable ones and good ones, I have a couple that are 10K
Old Jan 29, 2013 | 12:35 AM
Allkustoms's Avatar
I would get weight distribution for that weight class 3 hitches are only rated for 6000lbs without and 10000lbs with weight distribution normally your other option would be to get a class 5 if you don't want to screw around with the extra parts either way a 10" drop is easy to get I'm only suggesting you go this direction for legal reasons I wouldn't want you to get fined or worse have have your insurance not cover you in a accident from useing wrong hitch also check your gross combined weight on your insurance I've had customers have problems with the factory ratings being to low this is in canada so your area might not be so bad but I would think it would be similar everywhere my inlaws own a hitch shop that i've worked at for 6 years now they've been in business since 1973 and this is info I try to tell all of our customers
Old Apr 30, 2013 | 08:08 PM
richardwheeless's Avatar
i have a a drop 10" i pull 6 ton of logs with it and have a 350B john Deere dozer i also pull on same hitch it has been working fine for me pulling it with a 2006 2500 dodge diesel LP inj. after market injectors and a big cam turbo with a bully dog programer have it set to tow pull
it is a work horse i have had it on a dino and was shocked at what it was pulling on HP.
Old Apr 30, 2013 | 08:10 PM
CR9712v's Avatar
best guess is tractor supply..
