Clunking Noise When i Enguage 4x4
Old Jan 16, 2013 | 03:17 AM
MRutko's Avatar
Default Clunking Noise When i Enguage 4x4
hey guys, i just went to use my 4 wheel drive in my 06 cummins 6 spd manual, its an turn **** 4 wheel drive switch. the problem is that once i let off the clutch i get a clunking and grinding noise. Any advice/ input.?? Thanks!
Old Jan 16, 2013 | 03:28 AM
H.R.D's Avatar
Check u joints. Is the 4 wheel drive engaging?
Old Jan 16, 2013 | 03:32 AM
MRutko's Avatar
I don't know if it is fully engaging, once it started making noise i switched it back to 2wd.
Old Jan 16, 2013 | 03:34 AM
H.R.D's Avatar
Is it a constant grinding noise when you let of the clutch? It maybe a t case issue.
Old Jan 16, 2013 | 03:37 AM
MRutko's Avatar
yes it is constant, and sounds like it gets worse as I let off more, also, i tried 4 low. i noticed that it doesn't make noise as soon as i put pressure on it. the truck will slightly start to move then it starts.
Old Jan 16, 2013 | 04:14 AM
H.R.D's Avatar
Can you put all 4 corners on jack stands or at least the front and mess around with the front drive shaft? I would try to get all 4 up in the air and have a friend try to put it in 4 wheel drive and try to locate the issue.
1999stroker's Avatar
Check the fluid for metal shavings. Sounds like a locking issue where as ypu said causing it to not fully engage.
Old Jan 16, 2013 | 02:59 PM
MRutko's Avatar
alright I have a buddy with a car lift that ill trow it up on. thanks you the advice.
Boatman
Mar 20, 2015 10:00 AM
Dak_summers
Jan 22, 2015 08:45 PM
2FordStrokers
Jan 11, 2015 09:40 PM
dutchsupreme
Diesel Engine Conversions
Dec 13, 2014 12:26 PM
Sculpturesylvan
Oct 18, 2014 10:19 PM
