blow off valve
Old Jan 15, 2013 | 09:25 PM
garyg's Avatar
Default blow off valve
could i put a blow off valve on my stock 07.5 dodge dually
Old Jan 15, 2013 | 09:41 PM
Bigg Redd's Avatar
There is no need to, as your intake system has no throttle plate/throttle body. When fuel needs drop, boost drops slowly and methodically. There is no throttle plate (as in gassers) to suddenly shut to cause boost pressure to stack up behind it. That would be a waste of time and money. BTW Welcome to the site.
Old Jan 16, 2013 | 07:15 PM
coors_man_2005's Avatar
i have heard alot of mix about this. but yes you can add a bov. i have read that it actually good for the turbo. then on manual trans trucks it helps you get better spool time between gears because it allows the turbo to keep spinning at almost the same speed instead of having to play catch up everytime?? is this true i dont know but that is what i have read
Old Jan 17, 2013 | 09:58 PM
garyg's Avatar
Default 07.5 dodge 3500 4x4 6 speed
thanks for the replys and now i have another question,service required came on today but i jus changed oil & filter bout 400 miles ago. could it be the particulate,egr or fuel filter
Old Jan 18, 2013 | 06:43 PM
guessing you prolly around 76k miles or so if so its the crank case vent filter. no biggie. you can get the light off by doing. ( Turn the key to the ON position, pump the accelerator 4 times to the floor. Turn the key back off. Service interval dinger should be gone.) if you delete your truck just delete the ccv filter as well. im not sure if it would do anything to a stock truck?
RA113024
Mar 13, 2016 07:42 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
behrendt1061
Dec 4, 2014 05:49 PM
CumminsCrazed
Price Quote - Request A Price
Oct 13, 2014 02:35 PM
