P0628 code and truck wont start
Old Jan 13, 2013 | 06:30 PM
Mdcdrift's Avatar
Default P0628 code and truck wont start
Today i was sitting idling in a parking lot and truck shook and died. Restarted it and it ran for about one minute then died. Checked codes and saw P0628. Would it be the lift pump? If so, what would you recommend?
Old Jan 14, 2013 | 08:21 AM
dangerous1965's Avatar
Check and clean your grounds first. You can disconnect the fuel inlet line to the CP3 if you don't have a guage inline. Turn key on and see if fuel shoots out.
Old Jan 14, 2013 | 07:11 PM
Mdcdrift's Avatar
Well i finally got around to checking on it. took a little bit for the truck to start, but it finally did and ran. Didnt quit or hesitate. I am puzzled. Should i wait for it to fail again?? Im not sure if it did. What to get to replace it or if i should do it.
Old Jan 17, 2013 | 09:47 PM
kylemckay's Avatar
POSSIBLE CAUSES
Wiring harness
Fuel lift pump relay
Fuel lift pump relay driver circuit shorted to external voltage
Fuel lift pump relay driver circuit open
Fuel lift pump relay ground circuit open
Fuel lift pump relay ground circuit shorted to external voltage
ECM
Old Jan 18, 2013 | 08:45 AM
CLEAN your grounds!!
fivepointohno
5.9L CR Performance
12
Jan 25, 2016 01:07 PM
Saams69
Jul 20, 2015 11:21 PM
Tex_pipeliner
8
Jun 7, 2015 10:16 AM
Mike0885
May 27, 2015 12:07 PM
ronstop
Feb 26, 2015 09:48 AM
