06 5.9 / 48RE starts off in second gear
Old Jan 8, 2013 | 09:32 PM
mstepchinski's Avatar
Default 06 5.9 / 48RE starts off in second gear
Hi,
I have searched a few threads, but haven't found anything conclusive regarding my issue. When I first start my truck cold, the transmission hits all gears. After it gets warm, it starts out in second, and sometimes will not even go into first even if downshifted manually. I just replaced both the transducer and governor pressure solenoid. I used the proper fluid (+4).. This never happened before I replaced the solenoid / transducer - I was having the 1-2-1 shift issue and that went away. After replacing the 2 items, the truck shifted as it should have for about 2 weeks, then started in with this issue.
Any ideas?
Thanks in advance!
Mike
Excursion73
Sep 9, 2015 09:20 PM
Jun 4, 2015 09:30 PM
plumberjack
29
Mar 3, 2015 11:38 PM
ronstop
Feb 26, 2015 09:48 AM
rtbcoop
Nov 29, 2014 11:33 PM
