03 5.9 stock
Old Dec 26, 2012 | 11:43 PM
ogeeez's Avatar
Default 03 5.9 stock
I thought my truck was jelling up the other night but now don't know whats going on. It would only do about 1500 rpms and then start cutting out. then when I got on a rougher road the last mile from home I could barely move and had to restart about 10 times. It seem to run better longer if I let it cycle up before cranking it. so I changed the filter and now it runs good for about a minute and then dies. when I open the water drain I hear a big wooosh of air. ??? any ideas???
Old Dec 27, 2012 | 06:33 AM
steved's Avatar
Your lift pump has failed...the 03 and early 04 have a fuel bowl-mounted pump that will not pass fuel when they die. Geno's Garage offers a direct replacement...
Old Dec 27, 2012 | 10:37 PM
ecjammer's Avatar
I agree with steved. Your lift pump failed. Do not run it with a bad lift pump, you'll over work your injection pump. Then you're looking at bank to replace both.
Old Jan 1, 2013 | 02:11 AM
gasjr4wd's Avatar
Sounds like lift pump... I replaced mine with a FASS pump. I think it gives a little more umph... it's just a little loud. MUCH better filters! Makes the injectors last longer.
06dodgecummins
Jul 13, 2015 11:24 PM
brand97
For Sale
Jun 30, 2015 09:14 AM
wannadrag
May 25, 2015 03:07 PM
Moparts345
May 24, 2015 09:35 AM
EasTxOilfields
Mar 31, 2015 09:03 PM
