Shade Tree , Pro-Mechanics & Fabrication Discussion of Fabrication of various products form your diesel as well as welders, Power Tools , Hand Tools , Shops, Garages , Lifts And More Including Tips and Tricks
home made sway bar links..
Old Dec 11, 2012 | 04:46 PM
minncountryboy's Avatar
bulb home made sway bar links..
well i snapped my sway bar links off this summer and instead of spending the 90 dollars a side i made my own... the old ones were like 7/16 bolts so i went to 1/2 inch bolts bout 8 inches long, got new bushings from bds. and for my spacer between the the 2 inside bushing i took 5 inch black pipe, cut it to 4.5 inches, with flat washers, and a nylock nut. painted to sorta match the truck, and i included some pics.. i didnt know how well they would up but so far they are holding up wonderfully!!
ya i got a power steering leak, but for a 85 dollar gasket im saving up for a new sector anyhow
Old Dec 11, 2012 | 07:31 PM
tiremann9669's Avatar
Old Dec 11, 2012 | 10:42 PM
All for bout 35 dollars, the most expensive was the bushings.. 20 bucks for those, and 5 bucks for the can of paint. And 10 bucks for 2 pipes, 2 8"x1/2" bolts, 8 flat washers, and 2 nuts, haha, definatly beats the 90+ dollars.
Old Dec 12, 2012 | 06:25 PM
fordornothing's Avatar
should have got grade 8...
Old Dec 13, 2012 | 01:56 PM
If these snap off then I will be upgrading to grade 8 and go maybe an inch longer.. cause if you know the stock suspension they have some travel.. and before I had no travel so it put a lot of pressure on the old ones..
Old Dec 13, 2012 | 11:31 PM
HydroElectric's Avatar
props, they look good, my kinda fix
i would have done grade 8as well
Old Dec 14, 2012 | 12:49 AM
Thank ya sir ya I might upgrade em to grade 8 here after this winter or sooner
Sep 14, 2015 06:10 PM
carid
Diesel Bombers Sponsors
Sep 2, 2015 06:56 AM
autostroker
Jul 4, 2015 10:39 AM
