Diesel swap
Old Dec 7, 2012 | 06:04 PM
quincyj34's Avatar
Default Diesel swap
Im thinking of swapping to a diesel. Currently I have a 92 f150 4.9l ext cab. I have a friend that has a 97 van with a 7.3l turbo I could get pretty cheap or I was thinking of swapping in a 4bt or I could just go with a 5.8l. The truck will mostly be for a daily driver, few highway trips and towing a boat. Im sure sure which motor I want to go with since in terms of mpg the 7.3 and the 5.8 would get about the same. I know the 4bt is top dog in motor swaps, but I havent been able to find one. I know the 5.8l would be the easiest to swap, but I dont know which way I want to go.
Old Dec 7, 2012 | 08:13 PM
ElleryM's Avatar
Why not just sell your current truck and buy one already with the engine you want? It's not like you're sitting on a gold mine of rare trucks with an F150 and a 300 straight six, and the engines you want aren't a semi-exotic swap like a K30 with a 6bt.
F150s are intended for different uses than F250s and F350s. The frames aren't as strong, the suspension isn't designed for the weight of a big diesel, and the drive train will have to be replaced to accommodate the bigger motor.
Half tons just aren't designed for thousand pound diesel engines, and the 4bt isn't designed for pickup truck use.
351/5.8 in a F150 though? I'd imagine that's pretty common, but considering it was a factory option, wouldn't it just be easier to buy a new truck instead of going through the hassle of an engine swap?
Old Dec 7, 2012 | 08:20 PM
pouring smoke's Avatar
there are alot of guys that are running 4bt engines never had a prob with them and u wont have to change all that stuff there are half ton chevys supporting the wait just fine and in my opinion ford an dodge half tons were heaver sespension
Old Dec 7, 2012 | 08:45 PM
ElleryM's Avatar
I'm sure a lot of people have, but why would someone go for a 4bt instead of a 6bt? The 6bt is so much more with any extra work relative to the 4bt.
That's good for Chevy. The 6.2 and 6.5 were designed to fit anywhere a small block was. They both suffer from flaws as a result of their compromises.
What difference does it make? This isn't a one piece puzzle, and suspension will have to be modified just like everything else.
Old Dec 7, 2012 | 08:56 PM
quincyj34's Avatar
Well im not selling the truck because of sentimental value and the only reason why I was considering the 7.3l because I can get a a donor van with everything I need. Im well aware the I would have to change the front suspension to accommodate for the diesels weight. Ive seen half ton trucks with the 4bt. I am just looking for a little insight from guys that have done any of these swaps. To be completely honest I would rather do either the 4bt or 5.8l swap.
Old Dec 8, 2012 | 02:25 PM
seaglf's Avatar
The 4.9 weighs about 500 lbs
and the 4bt is 750 lbs so you would have to do some suspension work.
There are some guys on here that have put 6bt's in a f150 but I think that is riskie! I would hate to be going down the road and the ball joints brake or hubs, or something like that. There are plenty of 4bt f150 swaps though.
My thoughts are that since F150's didn't come with a diesel let alone a cummins then it doesn't matter which diesel you put in it. I would go with a Mercedes OM606, it has more torque and horse power then the OM617,and you could convert it easy to run without an ECU by using a OM603 fuel pump. And they weigh about the same as the 4.9. Also the are about the same HP and torque (stock) as the 4bt,also the don't vibrate nearly as much as the 4bt, one more thing there not as tall,so they would fit a 4/4 better.
Heres one on eBay, and I'm sure there are more, although I see more 4bt's then Om606's, and A lot of OM617's
http://www.ebay.com/itm/200775750394...84.m1423.l2649
Old Dec 17, 2012 | 09:09 PM
chevys supporting cummins thats the subject were on aint it not 6.2 and 6.5 never touched sespension
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
May 6, 2015 03:20 PM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
