check engine code after some troubles starting...
Old Nov 28, 2012 | 05:45 PM
minncountryboy's Avatar
Default check engine code after some troubles starting...
Alright guys.. so I went to start my truck and it would turn over but the batts sorta died so i had to jump it sadly, and it was your average extreme cold start, it wasn't plugged in it.. n now a code, starts fine and all just wondering what the possibility would be must say when i jumped it never heard it crank over as fast as it did
Old Nov 28, 2012 | 05:57 PM
H.R.D's Avatar
What code you seeing?
Old Nov 28, 2012 | 06:57 PM
Havent scanned it yet.. but its running fine.. that's what confuses me .. last time I had a code for the intermittent power to ecu/pcm it didn't wanna start n that was solved by cleaning the cables, I'm just wondering if my batts are shot cause when i had them tested they were pretty shy of of goin to the bad sad I think one was at like 670 cca and the other was at 500 cca so I'm hoping its just batts
Old Nov 28, 2012 | 07:15 PM
H.R.D's Avatar
Get them tested again, good batteries are a vital component to a healthy truck.
Old Nov 28, 2012 | 07:18 PM
Well and thing is there not the same cca rating and they looked a lil older when i bought the truck.. but will bad batts throw a code? And i tried the key on key off deal n it dont throe codes.. so ill scan it tomorrow and see what it shows... I really need to start pluggin it in haha thanks jerrod
Old Nov 28, 2012 | 07:22 PM
H.R.D's Avatar
You really do need two batteries rated the same, but dying batteries can cause all sorts of problems. So it very well could be your issue. Keep be updated when you scan it and we will go from there.
Old Nov 28, 2012 | 07:23 PM
Alright.. another I noticed was the alternator running a tad higher then normal.. also
Old Nov 28, 2012 | 10:48 PM
Diesel Addict101's Avatar
Bad batteries = Faulty computer readings and control. Could easily throw a code.
Old Nov 29, 2012 | 06:11 PM
Thanks diesel addict I'm plannin on scannin it in the morning
It was a Chrysler P1755 tranny power somthin.. but tranny is shifting perfect.. had batts tested they tested good but it was after a hour of running down the road.. so im pretty sure batts are in the nearest future for sure!
Last edited by minncountryboy; Nov 29, 2012 at 06:11 PM. Reason: Automerged Doublepost
burndiesel
10
Feb 7, 2023 01:15 AM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
Rebel_redneck
Sep 29, 2014 11:05 AM
