06 oil leak filter area
Old Nov 28, 2012 | 02:06 PM
rosso tweeks's Avatar
Default 06 oil leak filter area
Oil continually collects and drips very small amounts from oil filter area. Parking lot where I park every day looks like s---t. Any thoughts?
Old Nov 28, 2012 | 04:43 PM
Bigg Redd's Avatar
Well its vague, but I'll take a whack at it. Here goes: loose oil filter, oil filter o-ring gasket not seated properly, O-ring gasket defective, loose threaded plug on top of oil filter housing, ruptured/ rupturing oil filter canister (what type of oil filter are you using?), turbo oil line fitting loose or defective causing leak at filter housing, leak somewhere on turbo oil line........damn, just brain farted
Old Nov 28, 2012 | 05:40 PM
minncountryboy's Avatar
I have the same issue, but I think mine is the turbo feed line o ring or its loose. But mine is leaking at a very slow rate
Old Nov 29, 2012 | 08:23 AM
dangerous1965's Avatar
pressure wash it and then check it! Double oil filter gasket? Had to throw it out there!
Old Nov 29, 2012 | 10:21 AM
steved's Avatar
The first thing is did it just start or is this an ongoing issue (through multiple oil changes)?
cummins Pride
Sep 28, 2015 12:11 PM
Gomerpile79
Apr 9, 2015 03:45 PM
Bob V
Apr 6, 2015 11:02 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
ash23k
Dec 30, 2014 08:31 PM
