need some advice
Old Nov 27, 2012 | 09:28 PM
carpenter farms's Avatar
Default need some advice
I just had all 6 injectors replaced in my 06, truck smoke white at start and i have excessive blow by,NO shaking at any time, im thinking its the rings but im no mechanic whats yalls thoughts?
Thanks
Old Nov 27, 2012 | 11:24 PM
dangerous1965's Avatar
Melted piston! What made you replace the injectors? Bad injector = melted piston!
Old Nov 28, 2012 | 06:28 AM
It was running sluggish, no power, took it to mechanic, said I had a bad injector so I had him replace all them.
He said that's all he could find wrong. It runs great power wise now.just has lots of blow by and smokes at start. What's it cost roughly to have this problem fixed.
Last edited by carpenter farms; Nov 28, 2012 at 06:28 AM. Reason: Automerged Doublepost
Old Nov 28, 2012 | 06:58 AM
steved's Avatar
Stupid question...did you check the oil? Sometimes injectors aren't installed correctly, which causes the oil to be fuel-diluted. If it didn't have major blow by before the install, there really isn't a reason to have major blow by after...I would suspect your mechanic might not have gotten things torqued down correctly.
If you are talking a melted piston, you could be into several thousand dollars; and that's assuming the block isn't damaged.
Old Nov 28, 2012 | 06:32 PM
yes sir i checked the oil, and it seems fine as far as i can tell. i havent had the truck a month yet, seems evverything runs downhill as soon as i sign on the dotted line. truck pulls hard, and i just got out of it last night and noticed a cloud of smoke coming in front of my lights so i grabbed my flash light and seen it blowing out the tube. So i guesing my only opinions are to take it and have it tore apart?
Old Nov 28, 2012 | 07:09 PM
South Texas Goat's Avatar
Was it oil or hot air in the cold air making it look like smoke?
Old Nov 28, 2012 | 07:24 PM
I started it today and it was 70 degrees here and it still did it. I wish I could post a video of it.
brianj2077
Aug 4, 2015 09:06 PM
Spaky6.0mudder
Aug 3, 2015 08:54 PM
twm011
Feb 24, 2015 09:11 AM
jrsavoie
Feb 6, 2015 09:44 PM
lifted07sierra
Nov 6, 2014 08:24 AM
