Cruise control
Old Apr 6, 2007 | 07:09 PM
wyoranch's Avatar
Default Cruise control
Ok, just picked up my '93 today and the cruise dont work. What is the most common problem with them?
Also, im unfamiliar w/the cruise on these trucks. When i push the "on" button it stays down instead of just clicking back up like it will on a newer truck. I believe this is how they work, am i right?
Old Apr 6, 2007 | 07:16 PM
MnTom's Avatar
I would start by checking the fuses and then find the cruise servo (look under the left battery) and trace the vacuum lines for a leak. If you don't find a bad fuse or a leak in the hoses, check the servo and you might find that the battery leaked at one time or another and screwed it up.
Tom
Old Apr 6, 2007 | 07:28 PM
wyoranch's Avatar
Thanks mn, though i am having a small problem. Where is the fuse box?
Old Apr 6, 2007 | 07:39 PM
MnTom's Avatar
Not sure on yours, mine has two. One on the side of the dash you can see when you open the drivers' door, and one on the left inner fender. Look around the dash on the drivers side.
Tom
Old Apr 6, 2007 | 07:50 PM
wyoranch's Avatar
What year is yours? On my 2nd gens thats where they were, but they aint the same on 1st gens.
Old Apr 6, 2007 | 08:35 PM
MnTom's Avatar
I knew mine was different than yours so that is why I said to look around. If you want to, just go to the servo with the cruise turned on and check for power there. If you have power, step#2!!
Old May 5, 2007 | 08:09 PM
GO OVRIT's Avatar
Chances are, its your clock spring in the steering column. The switches go bad occasionally, but probably not the problem. Your fuse box is right above your knees if you're in the drivers seat.
burndiesel
10
Feb 7, 2023 01:15 AM
JBearSVT
Jul 9, 2015 06:16 PM
jdnetx
Jul 2, 2015 07:38 AM
Oil Igniter
Nov 27, 2014 05:56 PM
Cliffordthe24v
Nov 6, 2014 12:19 PM
