Construction Equipment Discussion of Diesels Used for Construction - Bull Dozer's , Back Hoes , Skid Steers , Track Hoes , Dump Trucks
Oil Grade And Weight
Old Mar 16, 2008 | 10:01 PM
wildbill's Avatar
Default Oil Grade And Weight
What's recommended in an 8V92 Detroit? Some odd reason they're running 15-40.
Old Mar 16, 2008 | 11:23 PM
DBogo's Avatar
im pretty sure that its straight 30 your supposed to run in them, i think the silver ones you run 15 40 in
Old Apr 18, 2012 | 09:04 AM
Eddiebuntain's Avatar
30 weight sounds about right, though I'd think 15w40 ought to work alright. What's it in, btw?
Old Apr 18, 2012 | 10:10 AM
rufushusky's Avatar
On the two cycle Detroit engines they recommend a straight weight oil not a mutli-grade. For most part the 2 cycles will shear a mult-weight oil to tar...
See section 2.2
http://www.detroitdiesel.com/pdf/voc...quirements.pdf
Should meet CF-2, IIRC Delvac 15w40 is the only multi-weight approved for CF-2 rating. Personally if I had a Detroit two cycle I would only run a monoweight oil.
Old Apr 18, 2012 | 09:01 PM
wildbill's Avatar
Doesn't seem like they make it a year before they have issues with them.
Old Apr 18, 2012 | 11:46 PM
Yeah, if they're shearing all their lube oil I'd imagine they wouldn't last long. Probably just using what's readily available on the shelf, or what they have on hand for more modern equipment. Here's hoping for better luck with the propper oil.
Old Sep 6, 2012 | 07:27 AM
killer.jensen's Avatar
I saw plenty of 6V and 8V series in the military. We used 15w40, didn't have any engine failures. Used 15w40 in everything, there is a reason it is refered to as fleet oil.
I mean diesel is what it is made for.
