Any Ideas
Old Nov 16, 2012 | 10:51 AM
ohioff's Avatar
Default Any Ideas
I have a 1998 Chevrolet 6.5 liter Turbo Diesel. When I start it or even after an hour of running it blows white smoke. I also have a leak in the coolant, as i have to refill it occasionally. Now before you say its the HG i replaced both the HG's and both heads. The truck runs great, doesn't leak any fluid, and the oil is clean. Could there be another place that the coolant could be dumping directly into the exhaust.
Old Nov 16, 2012 | 01:16 PM
racer55's Avatar
Cracked block,#8 cylinder quite likely.
Did you use new head bolts or arp studs when you did the gaskets/heads?
The stock bolts are 1 time use only,throw away TTY bolts.
The only place the exhaust is fitted to anything near the engine is at the exhaust ports,coolant must come through the cylinders or chambers to make it to the exhaust.
The intake is totally dry so no way for coolant to migrate that way.
363coupe
Nov 4, 2015 09:41 AM
Boatman
Mar 20, 2015 10:00 AM
Duramax2323
Chevy/GMC Duramax 01-04 LB7
Mar 9, 2015 04:34 PM
UniqueCopy
Dec 14, 2014 11:37 AM
txbiker
Jeep Liberty
Oct 27, 2014 10:36 AM
