Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
Does diesel go bad?
Old Nov 15, 2012 | 08:53 PM
Reeb's Avatar
Default Does diesel go bad?
I have a relative has a few hundred gallons of diesel its pretty old like he payed $0.60 a gallon old. is it safe to run or will it destroy my motor?
Old Nov 15, 2012 | 09:25 PM
Ltk's Avatar
Ltk
i wouldnt run it, but thats just me.. especially if he paid those prices for it thats some old diesel! id just use it for some good bonfires
Old Nov 15, 2012 | 10:41 PM
Reeb's Avatar
Yes it is OLD he bought in the early to mid 90s
Old Nov 16, 2012 | 02:34 AM
minncountryboy's Avatar
Ya I wouldnt run it.. I would assume its the same as gas.. and gas can go bad in matter of 6 months.. bonfires sounds like a good plan for it
Old Nov 16, 2012 | 08:19 AM
gunman41mag's Avatar
Moderator
Diesel typically stays usable for about a year or a bit more if kept at 20 degrees Celsius or lower. The warmer the diesel, the shorter the storage life. When kept at temperatures above 30 degrees Celsius, expect the diesel to last between 6 to 12 months, according to British Petroleum (BP).
Aged Fuel
When diesel goes bad and gets old, gum and sediment form. This reaction happens because of the reaction of the fuel and oxygen together. This sediment blocks up the filters and sometimes leads to an engine stalling. Also, the sediment and gum don't burn well and often lead to carbon deposits on the injectors.
Testing
To make sure diesel won't go bad immediately, manufacturers put the fuel sample through an oxidation stability test. They store the fuel at 120 degrees Celsius for 16 hours then measure the sediment deposits, according to BP. If the test produces 20 mg/L or less of sediment, the diesel passes the stability test. This mimics diesel kept at 25 degrees Celsius for a year.
Prevention/Solution
To uphold the longest storage life possible, diesel owners should drain water from the storage tanks every week, says BP. Storage tanks should have a cone-down shape to allow condensed water to collect. Keeping the tanks full, however, keeps water condensation to a minimum and prolongs the diesel's life. Also, every 10 years owners should empty and clean the storage tanks to prevent corrosion.
Considerations
Diesel sediment production happens quicker when exposed to dirt, water, zinc and copper. Also, exposure to higher temperatures decreases the diesel's usable life. Keeping the diesel away from these elements helps prolong its life and prevents engine damage.
Old Nov 16, 2012 | 12:26 PM
1993firstgennewbie's Avatar
I prety sure diesel can form allgie or fungus so I wouldnt run it in my truck but if you have a duece and a half go for it those things run on **** just filter it
Old Nov 27, 2012 | 02:33 PM
steve207's Avatar
not that i'm awhere of i had a boss that ran diesel that was 40 years old and the truck wasn't hurt smoke alittile but was so no diesel dosn't go bad like gas dos go ahead and run it it won't hurt it.
Old Nov 27, 2012 | 06:42 PM
Ltk's Avatar
Ltk
Based on one experience with your bosses truck?
Old Nov 27, 2012 | 06:52 PM
Moderator
i wouldn't run diesel older than a year old
Old Nov 27, 2012 | 07:33 PM
LORDDiESEL's Avatar
I'd filter it and run it in a 12 valve.
