stand pipes or bigger issue???
Old Nov 15, 2012 | 10:42 AM
1st Diesel's Avatar
Default stand pipes or bigger issue???
i have an 2003 f250 fx4 140,000 miles. for the past 2-3 weeks its been giving me trouble about not starting when its warm. it would start just fine when it was cold or the temp needle had dropped most of the way. but would usually take minimum 1 hour for it to start after shutdown on a warm motor. then last night it just died on me. it was running fine, i made a trip through town and went into a field to play for a min and was just putting around and as soon as i put it in 4 high and hit the brakes to turn around it died. would crank and crank and crank but will not start. my only guess is the stand pipes o rings are bad.
work i've done to the truck.
8 months ago - 3 injectors, 2 batteries, all filters and fluids
6 months ago - icp sensor
4 months ago - ipr valve, hpop, all fluids and filters
1 month ago - ficm replaced
Ok so oddly enough after it sitting for 7 hours i just went outside and she fired right up with no problems. Im gonna let it warm itself up and see how it acts. It did puff out a small amount of white smoke but i do know it has at least one bad injector cause i cam feel the misfire
Last edited by 1st Diesel; Nov 15, 2012 at 10:42 AM. Reason: Automerged Doublepost
Old Nov 15, 2012 | 02:07 PM
Mdub707's Avatar
Let us know how it acts, if it changes at all or anything... I'd think if you had a high pressure oil leak bad enough to have the truck shut off, you wouldn't be getting it fired up again that quick.
Old Nov 15, 2012 | 02:16 PM
1st Diesel's Avatar
Let her warm all the way up and she ran just fine. Was odd and confusing. I ran it around tue yard and kept popping it into 4 wheel drive since thats when it stalled amd she was fine. Shut her off and wouldnt fire up warm still. Only when cold
Old Nov 15, 2012 | 02:30 PM
Mdub707's Avatar
So no warm start... definitely sounds like a high pressure oil leak.
When it is running does it seem to have full power still? Any excess smoke?
Really the only way to track that down is going to be with an air test.
Old Nov 15, 2012 | 02:40 PM
1st Diesel's Avatar
Yea she has all of her power when warmed up. Runs great. Even when cold it runs like it should without any problems. no smoke at all.
Old Nov 15, 2012 | 02:54 PM
Mdub707's Avatar
Yeah probably just a leak then, not the HPOP going out.
Old Nov 15, 2012 | 03:00 PM
1st Diesel's Avatar
Better not be . I just replaced it. But if it does decide to go out, soon would be nice whioe its still under warranty .
Diesel_Daddy6.0
Sep 23, 2015 03:12 AM
dskewes14
Sep 14, 2015 09:19 AM
JKinni
13
Sep 5, 2015 11:09 PM
Oct 23, 2014 08:10 AM
Oct 8, 2014 08:10 AM
