Single wheel F-350 wanting to change
Old Nov 15, 2012 | 09:28 AM
westkentucky58's Avatar
Default Single wheel F-350 wanting to change
i have bought a used 1994 F350 with the tubro powerstroke 5 speed....it has a single wheel rearend....can someone tell me if i can change it over to dual wheels?
Old Nov 21, 2012 | 06:25 PM
can someone tell me if you can make a dually from a single axle 1993 1ton F350 4door?
Old Nov 21, 2012 | 07:15 PM
South Texas Goat's Avatar
Yes. look up conversion kits, depends on how much you want to spend as to what kit to get. Or if you just want looks.
Old Nov 21, 2012 | 07:53 PM
what im wanting to is put stock wheels and use simalators been told ill have to use spacers ...is that somehing ill have to use?
Old Nov 21, 2012 | 08:00 PM
slap a Dually wheel on there and see how close it is to the spring and brake line, You want or narrow dually like the cab n chassis this could do it. Otherwise need the spacer. You putting a flatbed or regular truck bed?
Old Nov 21, 2012 | 08:05 PM
it has a reaguler bed on it now and i was going to add dually fenders if that will work...
Old Nov 21, 2012 | 08:10 PM
Yes, you need the spacers for the front, but the back should be fine, check around you can find a whole bed cheaper than the fenders. Arrow craft has good spacers for the front. I gave 300 for my bed. Got it painted and installed for 350. To easy like that. All them oilfield welders getting flatbeds , lots of dually beds around here.
Old Nov 21, 2012 | 08:17 PM
thanks...this is the first Ford i have had and i need all the help to try and get it together....im going tuse it to pull a 28' enclosed trailer
thanks...this is the first Ford i have had and i need all the help to try and get it together....im going to use it to pull a 28' enclosed trailer
Last edited by westkentucky58; Nov 21, 2012 at 08:17 PM. Reason: Automerged Doublepost
Old Nov 21, 2012 | 08:22 PM
Just looked at Arrowcraft and they say it needs the spacer on the rear also, they are the pro's, do it right if you going to tow with it.
Old Nov 21, 2012 | 09:02 PM
ok..thanks....
