water pump
Old Nov 15, 2012 | 01:02 AM
rsexton721's Avatar
Default water pump
I am gettin ready to replace the water pump on my truck due to a leak and i just wanted to be sure of one thing before i did it do your need to put any type of sealent on the oring for the water pump to seal properly? Also if you do need a sealent what kind is the best? as always thank you in advance for your help.
Old Nov 15, 2012 | 08:35 AM
steved's Avatar
No sealant...its installed dry.
Don't forget to remove the two nuts securing the radiator shroud in place...it allows the shroud to collapse slightly allowing enough room to pull the pump up through the top of the engine compartment.
Old Nov 15, 2012 | 10:16 AM
rsexton721's Avatar
ok great thanks for the help
Old Nov 15, 2012 | 12:53 PM
TheOtherNick's Avatar
Also helps to take the idler pulley off and upper rad hose.
Old Nov 19, 2012 | 11:43 PM
rsexton721's Avatar
well tried to replace the pump today and the new pump leaked more than the old one thanks to autozone selling quality parts, had to put the old one back on till i can get one from cummins everything else went great tho thanks for the help ill just chok today up to practice
HardLuck
Jun 24, 2015 08:04 AM
HighVoltageHero
Apr 23, 2015 10:54 PM
klein444
Mar 8, 2015 08:19 AM
Lawrence D. Sanders Sr
Dec 16, 2014 11:52 PM
mpcampers
Dec 4, 2014 08:24 PM
